k5 interchangeable transmission???
thanks everyone for your ideas, I'll google "how to adjust shift linkage" and I'll do the driving test, and check the linkage I have there.
I'll let you guys know who everything go in couple of days.
regards,
Mohsin.
latest updates,
I put the shifting lever to the last position it could go to, it's supposed to be in (1), took off and the transmission shifted 1st & 2nd. I took the lever one step up and the transmission shifted to 3rd, took the lever one more step up and no change, the transmission remained in 3rd. I realized that there is something wrong in the shifting linkage, and the transmission itself.
I checked the TV cable and found out it's set to the maximum TV, so no drama regarding it, and furthermore, I reduced the load there and took a ride to check, still no overdrive. so I return the TV adjustment to the maximum again.
I disconnected the shifting lever and count how many clicks is there, and there was 6 clicks, meaning the transmission has 7 positions for the shifting lever which means P R N (D) D 2 1. when it's in "P", it takes 6 clicks to go to "1". so I tried to adjust the linkage, when I can reach "1" I can't reach "P" and vice versa. so I couldn't adjust it to have all the shifts reached.
then, I decided (desperately) to take a look on the governor since I don't have overdrive. and here were things went bad :D
I managed to remove the cover after many trials, but I couldn't remove the governor itself because I have a supporting rod going from the transmission to the transfer case and it's too close to the governor that when I try to pull the governor out, it'll hit the supporting rod and won't go anywhere. so I decided to return everything back and take it to a workshop since I don't have tools to remove that rod. I put the cover and put the steel luck over it, but it didn't luck perfectly :surepal: when I took off, the steel luck jumped aside and the cover reopened and I had the oil leaking outside the trany. I pulled over and put the cover again and tried to push it with a long steel rod because I can't hit it with a hammer in that so narrow space. I put the luck again, it seemed setting better. I add some oil and took off to a workshop that I used to deal with when I had my previous Chevrolet Caprice. I asked the mechanic (who I know) to take a test drive to diagnose the case. we took off, the cover set in place, the trany went 1st, 2nd and 3rd, then he pushed the pedal a little trying to reach a sufficient speed to hit 4th, that's when I heard a "click" sound and took a look from the side mirror to see a smoke behind us, and the cover on the street, and I went like,, Oops :eek1: we lost the cover... and he went like,, WHAT :yikes:.. did you open it??? and I said yes!!! :D
the good thing, we were one traffic light away from the workshop and we manged to arrive safe. my friend's (the mechanic) told me that since I have 1st, 2nd, and 3rd, that means I don't have to overhaul the trany. he'll check the solenoids and electric equipments inside the trany, and will reconnect the 3 wires cable on the driver's side, adjust the shifting lever, and I'll keep away from touching any automatic trany in the future :pimp: and hopefully I'll have overdrive if everything goes ok..
I'll let you know how it goes..
regards,
Mohsin.
