Hi evryone, first post here.
I have been a non premium member for about 6 months and have read a lot of posts while working on my project. All good stuff.
To give some background, I have an 88 K5 that been in the barn (thus the handle). I spent the winter months reading posts on this site and others and finally was determined to restore the k5. Upon inspection the body was way more gone after 12 years than I thought it would be. New plan. Found a stock California k5 with 140k miles and no rust. Had it shipped back to the rust belt.
I wanted to build something stout, so I procured a set of 1 tons, rebuilt the d60 front and installed one of the new gen4 elockers. The 14b with Detroit locker already had a disc conversion done and just needed the spring pads welded on. I had someone help me with that, and welded the spring pads on so we had 4-5 degrees of angle on the pinion.
The rear end was lifted with ORD 4" Rsf and stock springs. In the front I thought with the d60 and some of what I read that 3" would make it sit like I wanted, but the front was too low so I added a 1" zero rate from ORD.. Perfect ( should have listened to Chris as he recommended the 4" front leaf from the get go). I went with the bilsteins an installed new front shock mounts. Also did their crossover steering setup.
Received tires an wheels this week. Tooled around the yard, put it in a bind and checked for tire clearance, everything looked good. I'm running the stock rear driveshaft, with a conversion joint at the axle end. Replaced both u-joints on driveshaft.
Took it out on the road yesterday an it was all good until I got up to about 40 and left off the gas. Had a loud ratcheting god awful noise until I picked up on the throttle again and it went away. I could repeat this at will.
i put it up on jack stands and put it in gear this morning. Once I get it up to 35 or so, it looks like all of the vibration is at the front of the rear ds and it sounds like its tearing up the transfer case. With the truck on the ground, the tail shaft on the t-case looks to be hanging down 4 degrees. The driveshaft is at 21 degrees, and the pinion on the rear axle is at 10 degrees. I believe the rear shackle flip adds to the pinion angle and that is why the rear pinion is now 10 degrees.
You thought I'd never ask... So what do I do to remedy this situation?
Here are the before and after pics if you want to look.
? Based on verifying the level of the oil and projecting that to the pinion, I would assume? Assuming has got me into trouble at least a few times.
