When I measured the original axle out of my '90 K5, I got 12* up with the spring pads level. I seriously the SF14 at that and all is good, even with the 1" zero-rate.
That truck has has 4 different rear axles under it since I have had it, and this last one was the only one which wasn't factory stuff. No problems with the angle on any of them.
Now if I went with any more lift, I see that I may run into problems. The new axle, spring pads, and the zero-rate have all raised the rear 2" total.
