Need some help with the rear window. Typically in the past I have had an issue where I had to press against the tailgate while turning the key in order to get the window to roll down. I would just press hard.. or jiggle the tailgate in a out while turning the key at the same time… this always eventually worked and the window would come down…..until today.
Now is wont work at all. The tricky thing is the window will roll up…. Always. Only have the issue with the window going down.
Doesn’t matter if I use the switch in the truck.. or the key in the back … same result. Up works .. down doesn’t.
I wanted to believe the issue was related to the ground. But if that was the case the window would NOT roll up as well ?? ( I would think)
So my next thing is the safety switch… this would explain why it worked in the past when pressing the tailgate inward….or jerking back and forth. BUT… all my research shows that the safety switch ONLY prevents the window from rolling up….. the safety switch doesn’t affect the window going down. Can anyone confirm? Or give me some ideas ?
also take the cable off the motor and see if the motor goes both ways
