Hi, first post. Says I have insufficient privilege to post in the K5 tech section.
I bought my '83 K5 about six months ago for $650 from some hack, towed it home, got it running and have been slowly sorting it out. This forum has been a fantastic source of information. It had a 4 inch lift which I have removed (I am old and just needed the 4x4 to get up my cabin road).
To the point, I have a drive train vibration above 45 mph. The U-joint angles don't seem right to me (see photos), the rear end and drive shaft are almost parallel while the trans is appx. 10 degrees different. All my experience tells me the rear and trans should be close to parallel with each other. I removed some spacers from the trans mount when I removed the rear blocks and it should be as stock now. However it is possible the axles have been changed, speedo is way off. Truck was originally a diesel (now gas) and I believe still has the original 700R4.
Please ignore the missing header bolts and temporary exhaust, and all the oil everywhere. This thing was a total mess.
Thanks in advance for any advice.
Paul
Paul
