First things first: I have a 1990 K5 GMC Jimmy w/ a TBI 350, 700R4, NP241, 10 bolt front(LockRight and Warn Manual Locking Hubs) and 10 bolt rear, 33" KM2s.
Last weekend, I went out wheeling with my buddies. We did some rock gardens and some trails, then I found a nice mudhole that I thought I could romp through. 33s, front locked, no big deal right? Well that hole was a lot deeper than I anticipated (originally measured ~8-10"s deep) and I sank like a rock. It was buried past the bumpers. The water and mud splashed real good, when I went in, and when momentum was stopped, I shut the engine off. I was worried that the engine may/might have sucked in some water.
After about 10 minutes of ridicule, etc, I fired up the truck (started just fine too), and my buddy in his XJ pulled me out. We continue to wheel for about a half hour or so, going up some hills and more muddy spots along the way. Truck was running well, gauges were all good too, no SES light or anything. Nothing to indicate impending doom. Then as I started to descend a hill, all of a sudden, the engine completely died.
I made it down the hill with no power, and we started to trail-diagnose what was going on. Checked to make sure nothing came unplugged or unhooked, etc. Everything was muddy as hell, but looked alright. Tried starting, nothing doing.
Checked the starter connections, banged the starter with a hammer while trying to start, still resulted nothing.
Checked the fuse block and found the computer fuse was blown. Replaced said fuse. That should fix it right? Nope, still no start.
Towed it back to the parking lot, and winched it onto my trailer.
Got back to my buddy's house, and started checking wires with the multimeter. All three starter wires have 12V of power, all the way up into the cabin. Checked all other wires that go into the cabin, all have 12V as well.
Here is what the truck does when trying to start it. I turn the key to 'run'. I hear the familiar electrical click under the hood and the fuel pump's 1-3 second buzz. The dash lights come on too. When the key is turned to start, the dash lights dim (like they would when it normally starts), but there is zero result. No crank, attempt to crank, no sound of any kind, absolutely nothing.
Also, my column shifter is totally fubar'ed. It has been since I got the truck, but that may be contributing as well. On the selector, the 'P' position performs reverse, between 'P' and 'N' is neutral, N is OD, and so on. Recently it's been a bitch to find the sweet spot of 'park' in order to be able to turn the key to start.
Thoughts? I'm about ready to take my tires and front axle and junk the thing.
