troutbum_mt
A couple of questions, well several.
Hopefully this will turn into a search worthy thread that answers many of the winter type questions that seem to get asked. It would be cool to have a lot of the info in one place to direct people to....
First, let's talk about batteries. Obviously you want the one with the best cca's, but what brands in your opinions are more robust? I currently have dual die hards in my 78 with a 400 short block. It hit -20 and neither one is giving me enough juice even with a block heater. Once I am able to get the Blazer started it runs fine but is desperately trying to juice those batts. They are set up in series (neg of slave to neg of primary, pos of slave to pos of primary). Would a separator be a wise investment? I am guessing they are 4 years old or more since I bought this Blazer used and know it sat all last winter without being run so I plan on buying at least one new battery and running it solo until I can afford a second. Would a battery blanket be a wise investment as well? Never had to use one before.
Next question. Block heaters. Flow type from the radiator hose, freeze plug or magnetic patch type? I currently run a freeze plug type but with a 400 that is basically steam cooled, unless I am completely mistaken yet again, this might not be the best type. Comments, suggestions or input?
There is currently a thread about winter tires so I won't rehash that here. But my question regarding traction is how do you weigh down the rear end of your K5/Burb/Truck or do you run it empty and use chains? I need to throw some more firewood in the back of mine but have seen where people use these new fangled waterbed type doohickeys. Of course there are always sandbags.... Which gives the best bang for the unemployed buck?
How do you all winterize your rigs and in what order do you place your importance? What gear do you make sure to carry when you know you will be out alone and travelling during winter?
Sorry for the long post, but am basically trying to get a ton of info in one post for future search ease.
Hopefully this will turn into a search worthy thread that answers many of the winter type questions that seem to get asked. It would be cool to have a lot of the info in one place to direct people to....First, let's talk about batteries. Obviously you want the one with the best cca's, but what brands in your opinions are more robust? I currently have dual die hards in my 78 with a 400 short block. It hit -20 and neither one is giving me enough juice even with a block heater. Once I am able to get the Blazer started it runs fine but is desperately trying to juice those batts. They are set up in series (neg of slave to neg of primary, pos of slave to pos of primary). Would a separator be a wise investment? I am guessing they are 4 years old or more since I bought this Blazer used and know it sat all last winter without being run so I plan on buying at least one new battery and running it solo until I can afford a second. Would a battery blanket be a wise investment as well? Never had to use one before.
I don't tend to slide around a lot, but I also don't avoid using my chains when I get into deeper snow in the hills. I guess my chains could be considered extra weight, but I don't always carry them.
