key wont come out of my steering column!
86Cucvbeater
north carolina
so I ordered a new lock cylinder. when i took the old cylinder out the key came right out so I know the key being stuck has nothing to do with the cylinder itself. its something else. thats as far as I got tho because it got dark on me. So before I go out there tomorrow and dive into the steering column some more, anyone have an idea what the problem could be? In the steering column diagram I have, it looks like the possible problems could be the 'sector', the 'ignition switch actuator rack' or the 'ignition switch actuator rod'. Im thinking maybe this rod the diagram speaks of is bent because my tranny shifter doesnt seem to be going all the way to park. Anyhow, any opinions or what to look out for would be greatly appreciated as I havn't gone this far into the column before.. oh yeah, I have a standard non tilt column with th400 auto tranny :)
if your key is real worn looking you probably do need the new lock. mine had the same problem until i replaced the cylinder.
can you turn the key backwards and all the way forwards? It's probably the rod, and if not, it's more than likely the ignition switch.
Yes it will go all the way forwards and start the truck like normal. But when I try to pull it backwards i get some tension and the key wont pull out. The key pulls out fine if I take the ignition cylinder out of the column, so I do not think it is the cylinder.. How hard will it be to replace the rod? And by ignition switch, do you mean the key cylinder or something else? Thanks
