Keyed 12v along chassis
centexk5
3/4 ton status
Georgetown, TX
Installing an electric fuel pump along the frame. Is there a good keyed 12v I can tap into for a relay down there or am I running wires back up to the engine bay?
Not a clean 12v ignition source unless you have TBI wiring and want to use that.
On a square body ?..
There is a keyed 12V wire on the fuel tank sending unit,but I'd avoid tapping into that one,it'll likely affect the gauge readings and the fuse & wire probably isn't gonna like having more load on it..
I'd run a new wire to the fuse box and install an inline fuse,however the fuse box may have a keyed 12V "ACC" tap,but be sure it only gets power with the key in the "ON" position,not on "Accessory"--otherwise the pump will be running when your sitting there listening to the radio with the engine off..
