Keyless entry
Mudslutk51984
Registered Member
Commiefornia
I'm looking at a keyless entry kit on eBay.. can I wire the kit to where when I lock or unlock the doors it interacts with the lights? Also I wired up a keyless remote for the rear window is there anyway to combine the keyless entry and the rear window remote into one??
You'd probably need a kit that can trigger lights. Most likely use a relay to bridge the gap between the power to and from the headlight switch. I don't think I'd want to monkey with that too much, that seems pretty risky to me if something were to fail. If you had the headlight mod with relays already, triggering those relays would be fairly easy.
I'm going to set mine up with keyless entry as well, you'll have to keep us informed as to what you end up doing. I plan to keep mine simple, just trigger the door lock relay, that's it.
