primerk5
On a TH350 is there a gasket on the Kickdown cable?? I've got a trans leak that I haven't been able to stop. As far as I can tell its not the Pan gasket. I just put on a new rubber one last night and its still leaking comming from the kickdown corner of the trans. The cable is tight in trans. The transmission leaks down over about a month and then the truck won't move. It leaks more when its not running then when it is. Also I see no signs of oil comming from cooling lines. I definatly looks as though it is comming from that side of the trans though... I also replaced the dipstick tube rubber thing.
Your thoughts???
Your thoughts???
