58 apache
Great Gear Calculator Thanks
You figure going from 4.10 to 4.56 will net a 10 percent change in rpm, so say you were cruising at 2500 rrrr's with 4.10 then you would be crusining around 2700 rpm's with 4.56 gears. But your trans will have an easier life. I have burned up three 700r4's, so your right about wanting the biggest cooler you can find (the largest B&M one is very nice and what I have) I would also get a good aluminum deep pan, it adds a few quarts and will transfer heat better, and most of those pans have a screw hole in the bottom which would allow you to install a temp gauge (very important to watch). And with the 700 make sure your tv cable is adjusted properly, that is critical to the long life of that trans. If you plan on doing any towing your trans will like you alot more if you rearend has 4.56's.K5er4Life said:Doesnt sound like a bad price at all, and sounds like your getting the hang of exactly what you want. Good for you!!!![]()
However, 4.10's and 35"s on a 700 would make me worry a little bit. When you have a lower (numercially higher gearset) it relieves some stress on the trans. And as a result allows for less trans temps. This is the number one killer of transmissions is heat, it breaks down the fluid, allows the clutches to slip and before you know it you have a burned up trans on your hands. I had 33" with 3.73 and it wasnt bad at all but would have preferred 4.10's. The nice thing about 35" and 4.10 is lower cruising rpm but the 700 has a nice 4th gear (0.7) but running with 4.56 it would still be very tolerable on the highway. Besides that 700 has a 3.06 first gear which allows for some nasty launches and torque at the rear wheels comapred to a th400/350. Thats the only thing I miss about my 700 is the 1st gear and overdrive....go figure.You figure going from 4.10 to 4.56 will net a 10 percent change in rpm, so say you were cruising at 2500 rrrr's with 4.10 then you would be crusining around 2700 rpm's with 4.56 gears. But your trans will have an easier life. I have burned up three 700r4's, so your right about wanting the biggest cooler you can find (the largest B&M one is very nice and what I have) I would also get a good aluminum deep pan, it adds a few quarts and will transfer heat better, and most of those pans have a screw hole in the bottom which would allow you to install a temp gauge (very important to watch). And with the 700 make sure your tv cable is adjusted properly, that is critical to the long life of that trans. If you plan on doing any towing your trans will like you alot more if you rearend has 4.56's.
