Removed the driver side knuckle today. Came apart nicely. The lower king pin cover gave up a good fight but I eventually won.
The upper king pins were full of grease. The seal that is between the knuckle and the Inner C was cracked but wasn't cut all the way through. The King Pin itself was shiny and had zero pitting or gouges.
The axles came out easily and w/o any issues.
My MAIN CONCERN IS the upper king pins. I have watched every YouTube video and read as many posts on CK5 that I could find. I realize the difficulty in removal and installation.
QUESTIONS :
1) Are the upper king pins supposed to be replaced no matter what?
2) What's the Harm reusing the upper king pin?
3) The existing king pin is near mirror finished. Is that bad or just normal wear?
4) The replacement king pin is black oxide finish. Is that the normal NEW finish and it wears down?
5) Anyone have a photo of a "BAD" upper king pin?
6) IF IT MATTERS, I am replacing the nylon bushing with the brass bushings... Does that change the equation about using the old king pins?
Photos attached including knuckle king pin bore
QUESTIONS :
