I've been researching and reading a lot about chip tuning. And I've come to the conclusion that trying to dig up all the information on how to tune your own chips, and actually understand it, causes mass amounts of brain farts. I mean, come on. I see where a tutorial was started, on different sites, to help get a better understanding but it really isn't. So if anyone has a link to "How to tune your own chips for older farts" please let me know.
Anyway, from what I am able to comprehend, I was able to burn a couple of chips to see which .bin and .xdf I could work with. I already have an ECM that has been soldered with the G2 for quick replacement of the chip. And I've been data logging to see where the tune needs to take place.
One thing I have noticed on all the logs is that the KNOCK count is 0 and the BLMs were around 135-138. I have checked timing and it is set at 0. Fuel pressure was at 13 so I bumped it to 14.5 That moved the BLMs down to around 127.
Engine light comes on when you're cruising and you floor it to gain some speed (WOT). Some research says it could be header noise. But 0 count? Shouldn't there be some number besides 0?
My concern is if the knock sensor is bad. What is the best way to test it?
