OK, Fellas. The problem I have is that when I am driving my '72 around town I notice that when I come to a stop and press on the brakes I feel and hear a kind of knock noise that sounds like it's coming from the right rear. It doesn't do it when I first lightly step on the break but several seconds later. I think I also notice it a bit when I begin to take off from a stop but is kinda hard to hear with the roar of the engine and being that I have a full vert with no top on. I liken the sound to a golf ball rolling into the front of a truck bed when you brake and then into the tailgate when taking off form a stop.
I checked all the suspension bolts, checked the driveshaft ubolts and ujoints, body mounts, etc. and everything seems tight and fine. The blazer seems to brake and stop fine too. Is there something in the drum brakes of my 12 bolt that could be loose and making the noise? Haven't taken the wheel and drum off to see. Last I checked the R&P seemed fine but I do have one wheeling trip on them since I have seen them. It's not a big worry for me as my rig seems to drive fine but the noise is starting to make me more suspicious. Anything you all can think of that I may have missed?
Thanks, Hoby
Thanks, Hoby
You might be losing a wheel bearing. You are talking about the 12b, right? I didn't figure you put in the 14bff yet. The axle rides right on the bearing and can get the drum off center when the bearing goes south. Might wanna pull that wheel and drum, and maybe have a look at the axle and bearing, too.
It's easy, you can handle it.
Does the gas guage read correctly?
