I just picked up this 87 blazer and there is a weird knocking noise coming from the bellhousing/ starter area. As soon as you rev the engine it goes away. Any thoughts? Auto trans
Flywheel on an auto?
Talk about brain dead. I do not know the difference from a crank shaft and flywheel.
Need to stop putting parts on eBay while cruising CK5.
oh I see. So basically i run it until it gets worse? Then pull the trans and fix it
And that is if it happens when cranking it up......Sure.
Why wait until it is completely useless and then the engine can't start and or the vehicle won't move because all the engine does is spin where the crack is rather than transfer the energy through the transmission.
