The l29 burb I recently bought seems to run good when running.
But,,,. When starting it it'll crank and crank and crank AND crank..... Almost stumbling to life occasionally. And even being FI if I pump it a little while cranking it will catch and run.
Then runs pretty decent afterwards.
Seems to start batter after it's ran a bit and you don't leave it off long.
My thoughts are,. Fuel pressure bleeding off, the relay that bumps the pump when the key is first turned on is bad, or I've heard of ignition module issues with them but figured it wouldn't run at all if it was that.
No, I haven't really done anything to troubleshoot yet. Just getting some possible ideas where to start lol.
