Larger washer fluid reservoir
Predator
OKC,OK
Anyone converted to a more powerful windshied washer pump & larger reservoir setup. I went scouring the yard today for a LARGE reservoir with the integral pump and didn't find anything out of the ordinary. Anyone know of any vehicles that had massive reservoirs?
My K5 Buildup: <a target="_blank" href=http://www.geocities.com/gettin_deep>http://www.geocities.com/gettin_deep</a>
just curious, but what do you need more than a gallon of wiper fluid for?
and how powerful and large are you talking about?
you could get a washdown pump for a boat, and a 5gal holding tank, and it is 12 volt and pumps 2-3 gpm at 40psi
just an idea
chris
It needs a bigger motor.
what's in it now?
doen't matter it NEEDS A BIGGER MOTOR
89 350tbi/700r4h/np208/4.11's
I don't want to run out during a day of playing in the mud with the washers set on "constant."
Maybe a couple of gallons would work......
i was thinking of having two washer pumps/reservoirs. the stovk one, and a big one. something that clears off the mudd i go through. i think ill have it squirt from inside the sunvisor that way it cant get covered in snoe either.
beligerence doesn't justify intelligence.
<font color=blue>wheelers hate posers.</font color=blue>
<font color=red>79k15/400/700r4/205/38.5</font color=red>
Some of the older Volvos had a pretty good size resevior. I had a '70 and a '74 ( the '74 was about 2 gallons!) Them Swedes sure know how to play in the slop!
Real trucks don't have spark plugs!
I used a washer tank &amp; pump assembly out of an older Mercedes. It holds about a gallon and a half and has a built in washer pump that I hooked up to a toggle switch. Good luck.
David
<a target="_blank" href=http://www.extremeblazer.com>ExtremeBlazer</a>
