Last spring thread... hopefully
bassackwards
Tennessee
I am trying to ID the rear springs on my Blazer before I order the new front EZ rides.
I see no markings whatsoever on them. They have bolted clamps and each leaf other than the top one has a hole for a nipple on the pad to stick through.
The fronts were obvious Rough Country and all painted up with logos and part numbers but I am not finding anything at all on the rear.
There is a chance that they are stock but I have no way of knowing yet since I have nothing to compare them with. Are there any other clues that I should look for?
Then likely stock rear springs. As mentioned above, pics will confirm that.
need more . show length of spring and lift block and u-bolts .
looking stock or stock replacement units so far .
The u bolts and blocks are not stock. I figured that the markings and the way that the pads are attached would be pretty good evidence
sounds like the one i posted up . good solid choice for blazer for less saggy butt problems they tend to have .
Ditched teh Rough Country fronts today! Sold them cheap and while I had them off I measured them.
****All measurements are approximate but close enough for gov't work****
47" eye to eye
6" arch to center of eyes
2" thick pack
Looks like stock have a 1 1/8 arch and a 1 1/2 thick pack. There is over 5.5" right there,
