late 70's chevy 2wd gearbox.
RootBreaker
3/4 ton status
Williamstown, NJ USA
I swapped the shaft in my 4wd with a 2wd but my ps pump keeps puking out all the fluid.... so i put a new pump and new hoses but it still does it so I thought id go with a 2wd gearbox... what yall got?
Depending on how late 70's you need, I've got a good used one with just a small leak under the rag joint (needs a new seal). The hose fittings changed a little somewhere after the late 70's. It's yours free if you pay for shipping.
I will let you know..... I added a extender on my fill tube so the fluid couldnt leak out... and guess what I got a leak still... so now im thinking as i dont remember... but I wonder if I did not put the o ring in for the pressure line....
