The truck:
01 Chevy 2500HD CCSB 4x4
LB7 Duramax
407k miles
The history:
Had it for about 100k miles
Injectors replaced 1 1/2 years, 20k or so miles ago
Headgaskets done a year ago (did new, updated headgaskets and headbolts, new belt, new water pump, oil filter/cooler interface gaskets while there)
The problem:
Fuel in oil
The conditions:
Changed oil a week or two ago.
Last night, leaving work, truck idled rough.
Noticed oil pressure lower than normal (estimate typically 60-70 when at cold idle, 35-40 at hot idle)
Was at about 20 at cold idle, around 10-12 at warm idle.
Got it to the house, drained oil, got about 4 gallons diesel/oil mix out of it.
Replaced oil, pressures back to normal-ish.
Ran to town for supplies (probably 40 miles round trip), pressures began to drop again
Got to the house, walked away for a while (very not happy), came back later and noticed fuel dripping out and a puddle in the gravel.
Appeared to be leaking around front and rear mains and possibly oil pan gasket.
Drained approximately 4-4 1/2 gallons of diesel/oil mix.
The theories:
Bad injectors - don't think so because they are fairly new, and it only runs rough after getting way over full. Thinking maybe low oil pressure and thin oil causing lifters to not pump up, which leads to running condition
Broken return line, loose return line bolt, bad return line banjo washer - since it runs fine initially, thinking that the leak is on the return side of the fuel circuit.
I'm open to suggestions. (Preferably ones that are easy fixes, as all of my ideas are going to be labor intensive. Haha.) Has anyone seen this before?
LB7 Duramax
407k miles
The history:
The problem:
Fuel in oil
The conditions:
The theories:
. this was a few years ago now and she is still running strong .
