baker420ex
Registered Member
Hey everyone, I am in the process of installing new leaf spring bushings, with springs on the vehicle. The vehicle I am working on is actually a Dakota but as a previous k5 owner I know you guys on ck5 know your stuff. So I am here looking for some professional insight if anyone feels like chiming in.
I got all my bolts/old bushing off by cutting/grinding/drilling. I used the bolt and nut press method to install the new bushing. The issue here is I am about 1/8", maybe 1/4" out from having it completely seated and the bolt snapped. (FWIW this is a regular 1/2" zinc bolt 6" long fully threadded - only thing I could find with the required length and more than an inch or so of threads) Anyways at this point I am running out of daylight so I just bolted up everything on that side to clean up and call it a night. Also my washers I am using are now all conical shaped and my whole "press kit" took a wicked beating. Would I have better luck with say a grade 8 or better bolt? Is there another trick out there to help finalize the seating process? Just did this on a 4x4 s10 just as rusty with way less effort. Guess I didn't figure it wouldn't want to budge at the very last few turns....
If anyone feels like chiming in with any tips/tricks/insight/anything it would be greatly appreciated. Thanks everyone and thanks for reading!
..sometimes things just dont go well,no matter if you had proper tools,or the patience and skills to do the job..
