Leaf Spring Mounting Bolt Torque
johnathan
Ocean Springs,MS
Anyone know the torque for the front and rear spring mounting bolts.I was researching and I believe I have overtorqued them:doah:
If you got those fancy nuts with the plastic inserts so they don't loosen up every once in awhile , it would be easier to torque em and forget em :thumb:
don't forget to assemble them loosely, put the weight of the truck on the springs, THEN torque them. Helps the bushings live longer.
