Leaf Spring Shims
1HighK5
New York
I would like to know about leaf spring shims how big do they come and how many degrees is safe ect. Also where would I be able to order or get them from. I'm using 10 inch lift springs if anyone could give me any info it would help thanks.
Check out www.jkwoffroad.com
I got a set of 7 degree shims for mine from them. Good quality and quick responses. $30 to $40 bucks a pair or he will make custom ones. I had to get new centering pins for mine. I got them at NAPA. Pretty cheap. they are the bolts that hold the leaf spring pack together. The shim is bolted to the spring pack and the head of the bolt sits in the center of spring perch on the axle.
Do a search for front axle shims and do some reading. Some good posts about this.
