leaf springs bolts, how tight?
muddybuddy
1 ton status
Northern, VA
hey guys, how much do the i-bolts for the leaf springshave to be torqued?
thanks
YA, I use my BEEFY Impact wrench to take off and install leaf spring U-bolts. I once had one loosen up. It angled back put tire into rear of fender opening, and shaved off the leaf pack pin. Thats a job to replace that pin with a bolt and grind it down to fit in the little hole in the axle. So yeah go TIGHT on those bolts. Lock washers and nylon lock nuts for sure!!
:cool1:
thanks for the replies.
im actually talking bout the bolts that connect the leafs to the frame. any specific amount, or just as tight as i can get it socket style?
thanks
110 for the spring eye bolts? holy crap... I use locking nuts and probably put about 30 ft/lbs on them... is that 110 number an actual spec from a real source? sounds more like a u-bolt spec to me...
j
opps miss read your post 140lbs for ubolts. I ussually tighten the leaf springs bolts between 35-45 lbs.
That just had that happen to me, had to fix it on the trail. I'll be putting the impact on those things after I get one.
Ya its fun trying to compress your leaf springs back together using a C-clamp and putting a new bolt and nut through center hole, and then grinding it to fit the hole in your axle. But my CV driveshaft with 1350 U-joints held up to the axle being way outta whack. And its a good thing local law requires I have mud flaps or the fender would have torn up my tire and that wouldnt have been pretty while cruisin' down the highway!! :eek: :yikes:
That's more like it, 110# would crush the hanger into the bushing badly and create a very stiff ride. ;)
Tighter than this...
