6" used all spring lift rough country kit stock 47" front and 52" rear . there all there spring wise . might need some bushings . little rusty but not used much off a truck that sat most of its life .
looking for 300.00 + s/h to you . i have shipped fastnal to a lot of areas . last set of 4 i shipped to maryland and was around 170.00 . just had a BBC shipped to me from detroit for the same price .
super-lift 47" front 6" lift brand new older set purchased around 15 years ago just installed and never driven on . truck has bbc/4l80/205 combo sitting on it for half the time the springs have been installed . the springs were modified and had Teflon pads installed on each leaf and the bent over tabs bent up in prep for them to be drilled for bolts to let the packs flex and ride better .
looking for 200.00 for the pair + s/h to you
8" super-lift front 47" springs with zero rate installed . band new take out from a long dead project . were only installed for maybe 1 year if even that for mock-up needs .
looking for 300.00 for the pair + s/h to you
explorer pro comp rear 13711 88-98 style rear 5.50 inch lift with 2 extra leafs per pack added in .
these were used from a local friend years ago and were and still are in good shape and can rear the factory inked on part# . so they look to be low miles used springs . they were from the same project as the 8" super lift above .
looking for 350.00 for the pair + s/h to you
