It's supposed to be plugged the vent in the tranny and tcase take care of any pressure build up from the shaft going in and out.
I agree. But the pressure buildup I was talking about is between the end of the splined shaft and the inside of the yoke.
Of course the air can get between the splines and relieve the pressure or vacuum as it slides.
But there is a limit to how fast that air can squeeze between them, and if you hit a big bump going fast, that space can change really fast.
Whats really bad, is if transmission fluid leaks into that space and then you hit that bump.
Air will compress. Fluid will not.
And that fluid will not flow back through those splines much at all in that time frame unless the splines are really worn.
Which means that drive shaft will tend to act like a solid bar with no slipyoke.
Not a good thing.
Most of the slipyokes I have ever seen have a flat steel plate over the end of the yoke hole.
And they usually have a small hole drilled in that plate.
Some are solid with the hole drilled.
Its easier to machine the shaft hole and splines if its a through hole, thus the plate.
On driveshaft mounted slipyokes, that is the hole that the grease oozes out when you grease the slip part.
And the grease shoots out when you hit a bump the first time.
You're right that its not the right washer. I'm still groggy from turkey hunting. I just saw the star washer and forgot about the shaft sticking out the middle.
But I have seen them with solid centers that go on the end of the shaft.
