stock93
I have an 83 K10 4x4 with 36in buckshots. I have been going across some pretty deep water with it. I walked out to my driveway today and noticed gear oil with water in it leaking out of the drivers side front axle. I drained the fluid and it was way to high due to water getting in the differential. It only leaked maybe a 2"x12" spot of gear oil/water out of the end of the axle onto the ground. It has been parked for over a week. Would this be due to the higher gear oil level or should I replace the seal? If I do have to replace the seal, I have to pull the whole axle shaft out of that side correct? Do I have to pull the differential? I'm pretty sure the water got in through my vent line. I'm pretty sure the axle is a corp 10 bolt.
Thanks,
John
Thanks,
John
