Creek
Registered Member
The oil cooler on my 90 Blazer has sprung a leak. The dealer wants $297.33 for a new one. I have a B&M transmission cooler that looks identical except that it doesn't have the mounting brackets riveted to it. It also has 1/2" taper pipe thread fittings. The stock cooler has 1/2" straight pipe thread fittings with a seat for the tube and o-ring. Does anyone know where I can buy one with the correct fittings for less than $150.00? Anymore than that and I'll spend the time to properly adapt the trans cooler.
David
David
