rgretzinger
When I bought my k-5 from previous PO the transmission fluid was low so I filled it up. The vehicle did sit for quite a while so hopefully it's just a worn seal/ gasket. Quick question the fluid leaking is pink/red if the fluid was bad (burnt) before would it look red/ pink while it's leaking now? Trans shifts smooth so hopefully the gasket just needs to be changed. It's leaking just a little bit about a teaspoon and a half or so. I am assuming this is normal right?
