My 14bolt FF axle is leaking from the pinion oil seal, around the yoke, and around the pinion support itself.
Do i need anything special to replace either seal? Im not familiar with the crush sleeve or pinion preload when changing the oil seal and i fear what i do not understand!
Does the pinion support pull out if the carrier is still in the axle?
