Leaky injector
airemdwn
Pennsylvania
What part should i replace when the injector is leaky at the top where the connectors are?
Is it simple like the gasket or major like the injector dying? It looks like it bubbles up from the pins where the connector clips on.
I have a spare 4.3 TBI with yellow/blue paint on them would i be able to swap that out. the leaky one has no paint or markings at all.
The injector itself is bad and that can't be repaired so it's time for a new injector. The 4.3 injector will be a different lb/hr injector and won't work properly. There are numbers on the top of the injector but they are sometimes very hard to read and most if not all 350 injectors are black/orange color on top if the paint is still visible.
