blazerbones
Hi all,
Got a leaky side/rear window (& really stinky wet insulation!) in my '90 burb. I've seen some info about changing out blazer top windows... easier if you have the install tool and ok to use black rtv on the seal is what I read.
Can anybody confirm if there's anything else needed to change out a SUBURBAN side/rear window? Tips/tricks? Where to get the install tool?
Has anybody had those sliding windows from LMC??? Pricey, but I LOVE the idea of sliders in the back of the burb.
Also,
It isn't leaking yet, but the flange that holds the a/c lines where they pass through the bed (rear passenger side corner) looks like the likely culprit for the next leak. I'd like to address this while I have it all apart. Is there a seal that goes there?
Also,
