leaky speedo cable
ugly duckling
Newbie
silver valley, north idaho
this newbe needs a little info on the speedo cable that goes in the transfer case its a 203 its been leaking now for a couple of years.i drive the duck mostly on the weekends but never on long trips untill recently.when i looked in the rear view mirror it looked like i blew a head gasket or two.but when i started to look around and under, the underneath was covered in oil how can i fix this? is it costly? please help (the wife won't stop complaining)
There is actually a small o-ring seal that you can get to go in there and replace the original one :thumb:
Speedo leak
Any parts store should have the kit, it's not too bad to do. Loosen the cable, remove the speedo assy, replace you rings and whatnot, screw it back in, and your done!
