LED Worklight?
I have 2 of these
some people have an issue with the switch on them being hard to push. One of mine is a little like this other newer one is fine. I use them all the time. Came with wall charger and 12v charger
03473904000
35 LED lights. Swivel hook on top rotates a full 360 degrees.
I've got the one in this link. I like it, but the charge is only good for a couple hours, then it starts shutting off on it's own.
I have 2 of these
03473904000
I have this same one and I absolutely love it. I keep it in my DD in the rare case that I get a flat or have a break down. The magnet attachment makes it very handy to hang wherever you need light.
As for the switch being hard to press, I have seen this with mine and found that a slight rotation of the switch housing will realign the switch and it works great.
I have the same light as you guys and found the exact same thing, a little rotation and the button works fine.
For big jobs I stick to big halogen lights but for small stuff I really like my "joby". It has 3 magnetic feet and is small enough to fit right where you're working and its much brighter than you might think.
