Lets play what looks bent
sponsoredbydad
Dune Slaying Sand Junkie
- In Memoriam -
Dana Point "So Cal" "The sue me state"
Somethings not right.It has always had a small tweak but seems to be progressing after every flight. Axel tube looks 90ish coming out of the diff, hubs are good with solid bearings and no slop, what is the piece the ball joints press into called. I think that's where I'm guessing is bending. Maybe the inner C's but don't really think so. I'll get a couple better pictures when the sun moves a bit.
I say the inner "C". Lots of leverage at that point, and yours isn't gusseted.
Nice work, I'm definitely a fan! :waytogo:
I have mine gusseted to withing 3 inches of the inner c. Bent right there. So with none of the tube gusseted, I will bet it is the entire tube on that side.
I'm no expert, but wouldn't the truss underneath keep his tubes from bending?
With both tires on level ground, i would measure the bottom of each lower ball joint. The large spacer on the front hub place a lot of load on the front spindle. I will guess front spindle is bent. With the tire on does it rotate straight or wobble?
Trailer level? probably not, truck level? no, The focus is on the axle tube to the diff (If anything the axle tube is bent slightly down) vs the inner c to (lack of real name) outer c that holds the ball joints. I'm tearing it apart as we speak and I'm putting my hopes and dreams on the spindle and what it attaches to. The tire rotates perfectly straight. It just has a lot of camber
Stance bro
Chris
hub and rotor mount to spindle
spindle mounts to knuckle
knuckle has ball joints
ball joints go into inner C
inner C is welded to axle tube
my money is on one of those LOL
