In many cases the electric fuel pump is not the fault,it is the power wire coming from the front of the car (fuse box,to ignition switch) that is the culprit..the wire degrades over time and gets gangrene,and the connector at the fuel tank is noted for poor connections and corrosion--several new pumps come with a new connector,and the warranty is voided if you do not install it--but if the wire is faulty,it wont cure the issue..
My friend who runs an auto repair shop has learned not to condem the fuel pump right away when a car gets towed in and he's told by the tow truck driver "I think its the fuel pump--didn't hear it running,and I banged on the tank and heard it start working,then I could drive it up on the ramp truck"...
Too many times he just pulled the gas tank out,bought a new pump,installed it,and the new pump worked,the car ran fine again--but some came back dead a short time later--then he'd do what he should have done at first--test for power at the fuel pump ,but DO NOT use a simple test light,volt meter,or LED test light--those may light up or show 12 volts,but it is the amperage the wire will pass that matters...
He has now made up a test lamp using an old halogen headlamp--he hooks that to the pump's power wire and ground,leaves the key on several minutes,and watches the lamp,more than once it starts to dim,or flickers,then finally goes out or just glows dimly..
The faulty wire just cant maintain the amount of current flow it needs to run the pump continuously ..
To fix that ,he runs a new wire from a spot in the fuse box that only gets power with the key "on" and during cranking..and uses a new connector plug at the pump...
One car he had,an Oldsmobile,"ate" 2 new fuel pumps before he found out it was the bad wiring causing them to fail,low voltage tends to burn up electric motors..on that car,he also found a bundle of ground wires hidden behind the passenger side kick panel were all corroded to death,that were plugged onto a bus bar type of ground junction..he cut them all back to clean copper and crimped a ring connector on them all,and ground a bare spot on the sheet metal ,used a sheet metal screw to ground them--the car never had the issue return again..
Some cars with HEI have the module control both spark & fuel delivery,and either side of the module can fail or work intermittently --other cars using a crank sensor wont get and fuel pump pressure or injector pulses if it fails..
If one injector shorts to ground the engine wont start or run either,seen a '86 Buick Somerset do that not long ago,my friend figured it out,after several other shops in town gave up on the car..(and raped the owner for over $600!)..most cars with electric fuel pumps also have the oil pressure switch wired in the circuit,if that fails it can shut the pump down,but still work the idiot light or gauge..
Chances are after sitting so long the car may well need a new fuel pump,but I'd check the wiring good first..a new pump might work temporarily with poor voltage or connections,but you cant trust it and it can ruin the new pump in short order..
