Let's see some 14BFF Disc Swap Pics
BGKYK5
3/4 ton status
on the crapper...
Let's see some 14BFF Disc Swap Pics - I'm looking specifically for how you ran the rear brake lines. Did you use a straight or angled banjo, did you have to modify the banjo or caliper, how long was your hardline vs. flexible line, how did you route the lines etc.
Gonna be ordering some brake lines and I want to see what you all came up with.
I don't think I even changed anything on mine, used the stock hardlines (my truck had a 12 bolt, brake lines may be different) and then attached the stock front brakelines from those to the calipers.
