Lets see some IFS rigs...
SAS on coil springs? What is that set-up?
its the way everyone should have been doing it:D
ford radious arms, progressive rate coils, track bar and cross over,
custom shock hops, engine cage, tranny crossmember and engine crossmember..
ill be posting finished pics soon, right now im doing a shackle flip in the rear:p:
Well, at least the 4.10's and the big block won't sweat the 35's. Hello 10mpg though.;):p:
Know if it's a 14SF or a 14FF?
I've seen both in that generation and it's always interesting to see what shows up under what.
14FF (well, 10.5" ring... they're all FF right? haven't pulled the wheel to look at the hub)
Lift is RCD. Score!
Needs an alignment.. and yeah, 10mpg is about right.. I just spent a LOT on gas getting from FL to South TX!
Yep, all of the FF's are 10.5". Some got the 9.5" 14SF.
Might want to look into having the subframe components welded together to keep them from shifting around. Seen that before with the multipiece subframe lifts.
truck yum
Is that CAGE kit or custom? And don't you have a build thread somewhere?
well im the iddiot that makes the ugly bumper
and the rie is the 11r16 michilin.. measures a 38
skinny sucker though
