Lets see some suspension flex...
[ QUOTE ]
Ryan....you did show off the 5 minutes after that pose shots? Hehehehe.
DW
[/ QUOTE ]
Hey will you be at Blazer Bash? Good to see you over EJS. And my truck is not a fire hazzard due to wiring any more. /forums/images/graemlins/grin.gif
Carnage was a smashed in door, split the back of the cab off the bottom part (rust), crushed both rear spring perches into a U-shape, wiped out a brake line (hit by the spring perches), bent the front of my frame straight - it used to lean to one side and I had an add a leaf in it, and I think that's it. But I did make the magazine, and put on a good show. And the body was on the way out anyway.
Ryan
How it all ended up:
The 44 was wedged under a ledge and it took two winches to hold me out of the crack and one to winch me backwards out of it.
Max,
Those were from Upper Proving Grounds....
We ran outta time, and had to turn around and come back out of the entrance. /forums/images/graemlins/frown.gif
Marv
Damn! I gotta check that out in person the next time I am down there /forums/images/graemlins/peace.gif That looks sweet. Too bad you had to turn around.
