wasted wages
1 ton status
who uses 'em ? any pro's - con's ??
I really don't want to pull my rear axle apart to weld the tubes to the pumpkin..From what I understand,,to do it correctly, the housing needs to be heated,, then welded... then buried in sand or blankets to let it cool naturally......not real convenient with a built axle in the truck..
so,, using a truss... does it do anything to stop the tubes rotating in the housing ? or is strictly for resistance to bending a tube ?
I have looked at Kurt's design ( the back bone )
http://diy4x.com/cart/index.php?route=product/product&path=18&product_id=151
and Ballistic's design...
http://www.ballisticfabrication.com/14-Bolt-Rear-Axle-Truss-_p_1493.html
The only thing I dislike about kurt's bolt on kit is it probably doesn't do much to stop the rotational forces...the kit also comes in weld on...
I guess what I'm asking is what is the main purpose of the truss?? to stop rotating forces or to prevent bending of the axle tubes or both ?
Discuss....
Discuss....
