I'm getting ready to do a cab swap on my crew cab, and in the process I was going to move the tank. I'd like to re-do the fuel lines while I'm at it. I'm running a stock TBI 454.
The way I see it, I have 3 options (aside from stock-type fuel lines):
1: Braided lines with AN fittings
Pros: Durable, look cool
Cons: Most expensive option, can be hard to cut (from what I've read)
2. Nylon lines with push-on quick-connect fittings
Pros: somewhat cheap, quick-connect fittings are cool, easy to fix if damaged
Cons: can get melted? aren't rated as high for pressure (wouldn't be a problem for me)
3. Fuel safe rubber hose with push-on fittings
Pros: cheap, simple, easy to fix if damaged
Cons: easily damaged? handle the pressure?
Anything anyone else would add or take away?
What are you running?
Also, what fitting sizes and line sizes are on the fuel system as a whole (for future reference for me or anyone else)?
This is what I've found so far. Correct me if I'm wrong.
Supply line: 3/8"
Supply line fitting at throttle body: 3/8"
Supply line fitting at fuel filter: 3/8"
Supply line fitting at tank: push-on rubber hose with clamp
Return line: 5/16"
Return line fitting at throttle body: 5/16"
Return line fitting at tank: push-on rubber hose with clamp
I don't have much experience with the fuel system on our trucks so any info is appreciated.
Supply line: 3/8"
Return line: 5/16"
). Some guy recommended this stuff and it looks pretty good. I'm considering it for the tank to steel and steel to TBI runs.
