Let's talk backspacing.. and 1-ton wheels..
XHitman396
Broken Arrow, Oklahoma
so first off, i realize i hear it all the time, and i may have looked it up once, but what exactly is backspacing, and what is it used for (i.e. necessary to have 5" backspacing over 4.5" backspacing)? this will probably lead to another quesion (just so you know ;) ) and with a 14bff, is a 16 inch rim a must? or can you clear the drums with a 15"? thanks.. oh, and another random one, does all 1/2 ton break lines/pressures work for 1 ton breaks (10 -14 bolts)?? thanks again..
Pretty picture:
I run 15x10 with 4" of backspacing steelies on my 14bff with no grinding and a little bit on my 3/4ton front calapers. My 10b brake line matched up with my 14bff.
about 4" backspacing is the max you'd want to go on a fullsize with large tires without rubbing steering or frame components. I've got 2.75" BS on 15x8's, but hate the look. They look fine to everybody I talk to, but I want them inboard of the fenders, so should have ground my caliper. 15" wheels will clear 14ff drums, but not front calipers, those can be ground down, but the backing plate/guard piece will need some severe clearancing or to be removed
it's best to get your backspacing right in the center, ie, 4" on an 8" rim, the closer to the centerline the better it handles and less stress on the bearings.
