First off, Bobby, your a dumb ass. You dont need two alternators. Everyone knows you can just bolt down a gas powered generater in back, this is called a SPLIT system. Just route your outgoing generator power directly to the battery cable,the negative one. This way it will make you go faster, and give you tons more horsepower,and remove the need to get and aftermarket mallory ingition. Just fill it up the same time you fill up your truck. And It will be really loud, (supposed to be that way),,,,,,just roll down the windows so the smoke dosent fill up the cab, and crank up the tunes. This is good to wire directly to your stero amp as well. Also, at christmas time ,,,you can run a bunch of cristmas lights on your truck (the flashing ones) to be more decrotive. You can also mount Santa on top of your truck to match. I hope this helps. /forums/images/graemlins/screwy.gif
And while you're at it, get the gas powered leaf blower out of the tool shed and attach it under the hood somewhere in the engine bay with bailing wire and duct tape.
Some 3" PVC will work to connect it to your engine air intake plumbing.. Fill that sucker up when you fill up your truck and the generator in the back..
When someone pulls up next to you at a stoplight and wants to race, say hold on, get out pop the hood, and start up your leaf blower...
Wooollaa... Instant 20 lbs of boost. /forums/images/graemlins/waytogo.gif /forums/images/graemlins/woot.gif /forums/images/graemlins/whistling.gif
/forums/images/graemlins/rotfl.gif
[/ QUOTE ] Ahhh, yes, the good ol custom leaf blower cold air intake system.This will need to be adjusted though, at higher altitudes.To prevent any leaning of the motor.(been told that)........If you want to run two alternators, bobby, you have alot to learn baby bird. I agree with Ryan on this one, if your going this route, its important to run the Tripple Nipple Launcher style intake system (as described above) Hope this helps /forums/images/graemlins/thumb.gif
Oh my God guys, I'm gonna piss my pants. /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif
