Lets Talk Taps
Mudstud
Memphis, TN
Grainger has my 37/64 drill bit on backorder for several weeks now so am looking at alternative places to buy. This is for drilling/tapping my gear box once again for assist. Going with 3/8-18 NPT. In doing so I noticed a couple versions of taps.
This one says 1/4 but it is teh pic they show for all taps of this nature.
Irwin Taper Pipe Tap, 3/8-18 NPT
And then there is this one.
Value 3/8-18 Nptf Hss Dryseal Pipe Tap
It looks like the second one might work better to get into the dead end holes- the viens. Might could work without having to grind a tap down.
The names of these taps brings up another question. The fat one says NPTf dry thread, so does that mean the first one requires a sealant when putting the fitting in? I have two taps like the first one.
Most taps are designated #1, #2, or #3. A #1 tap has essentially no threads at the the end. They are several inches long. A #2 tap looks like your first picture, with threads starting at the end with a uniform taper. A #3 tap looks like the second picture, with an accute taper but fully threaded. A #3 tap would be used to chase buggered threads in a 90 deg elbow.
if you were to thread a hole from scratch you would use a # 1 tap to cut the threads. If your tap bottoms out without using the full length, you would then use a #2 tap to finish threading the hole.
Most taps ( and bolts) come in two thread sizes corse ( 3/8 - 18 ) and fine ( 3/8 - 24 ). Make sure you use the correct one.
The big difference between those two taps is one is dry seal (NPTF) and the other is not (NPT). The NPTF threads rely on interference to create a seal so that sealant is not required if you have a full thread engagement.
However, since you are taping a steering box with less than full thread engagement I would recomend the NPTF tap AND use sealant of some sort.
Also McMaster-Carr is another good source for stuff like this.
www.mcmaster.com
Are you talking about pipe taps? Because they are different from UNF/UNC threads.
Home depot or your local hardware store should have the drill you need.
Tarey
napa will prob have bit you need and I have 2 taps for the job, a normal one and one I lopped the last 1/2" or so off so I can run my normal one till it bottoms out then my shortened one till I get the thread I need
