So you want to raise the nose or lower the rear?I just purchased a 2014 Silverado 1500. It only has 5500 miles on it so I don't want to really change anything with the suspension but I want to get it to sit level. Any recommendations for a leveling kit?
Sorry for the shitty pictures, as you can see I took some last night.
A decent rear lowering shackle kit is around $50, I used the mcgauphy 33037 on my 2016 gmc. If its still not level you can pull the factory block out too, mine was single cab so I had to go this route. Most the crew cabs sit level with just shackles.
Never mind now I see it’s the same shackle just two two mounting holes. Did you set yours up for the 1” or 2”?They have this on Amazon with free shipping. Did you use the 1” or 2” shackle
