Life expectancy on a highangledriveline?
juanblzer
Chandler, Arizona
Okay...
I asked Jesse but... I want to hear what other customers have to say. I have a 14 bolt and an np208 and I'm planning on ordering a rearshaft from HAD. /forums/images/graemlins/grin.gif
what is the life expectancy like? I run highway speeds at least 5 days a week (70+) and I wheel as often as possible. Will the driveshaft last over the warranted year. Opinions and such appreciated! /forums/images/graemlins/laugh.gif
I would hope so for as much as they cost!
My take, though I don't have one, would be that is better than a stock driveline, and stock drivelines last a long time, usually suffering a painful death off-road /forums/images/graemlins/rotfl.gif So I think you'll be fine /forums/images/graemlins/thumb.gif
Drive shafts need maintance. They need U-joints. If your have it properly installed then 100K no problem. What will make them fail is getting the U-Joints full of water and crud.
mud and water are not my favorites... I change the ujoints once a year (an offroad racing technique that's pretty popular) anyway and my angles are not extreme. If it can last a few years that would be great. Looks like I'll be ordering this monday. SWEEEEEEEEEEEEEEEET!
I have one in the front, 1350 CV w/1410 at pinion. I believe it's a 35* unit and I had to clearance grind it some, too. /forums/images/graemlins/blush.gif I've thrashed it HARD for about 10 months and so far, so good. I say go for it. Plus, Jesse is a great guy to deal with. /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
Will
Believe it or not but I have wraped my U-joints with duct tape when I go Mudding and this keeps them clean.
They only lasted a few hours in Jesse James Bronco /forums/images/graemlins/eek.gif /forums/images/graemlins/ignore.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif
But even so, I'll be ordering a couple for myself. /forums/images/graemlins/thumb.gif
[ QUOTE ]
[/ QUOTE ]
That's because they put quality parts in a non-quality vehicle /forums/images/graemlins/grin.gif
At least Ford found the problem and circled it. /forums/images/graemlins/tongue.gif
If you give the cap on each u-joint a very small tack weld where the crown of the cap seats against the square ear on the yolk, it will keep it from wiggling out under pressure.
Keep the tack small so that you can chissle it off when you need to.
/forums/images/graemlins/usaflag.gif /forums/images/graemlins/k5.gif
