Lift input?
87k5350
Palm city, Fl.
Ok, so a couple of members helped to change my mind on adding a 3" body lift to an already lifted 87k5. It has now a 3" spring & block in the back and spring in the front. I need to clear 37" tires with out trimming, its a 4x4 so shakles? or what, any input would be great. Thanks
8 inch springs should do fine. lose the block, just get lift springs all around. since you're not interested in cutting the fenders, you're likely not wheeling hard - so you shouldn't be dissappointed with tall springs that provide little wheeling performance.
Thanks for the input. It wont be used for hard wheeling, the rest of the drive train wouldn't be very supportive either so at thispoint I just want clearance.
