Lift kit
I'm happy with my Superlift.I don't crawl rocks, don't have a gazillion hp and it's just fine with me...Just weekend wheelin' through the mud and snow.:D
MTChevy said:
cant go wrong with 4inch TC fronts and a shackle flip rear
I'm considering asking for this for my birth day.:bow: I'm just trying to decide if I should go with a raised steering arm, or dropped pitman arm. I've heard that the raised arm will have a bit of bump steer with only 4", but I guess I could go zero rates all around. I would also need to address drive shaft angle, but it should be close since the shackleflip actually points the pinion up (I'm just scared it may point too far up on my burb, due to the long wheel base). I still need to decide on what shocks I want to use, and which extended brake lines I need. I guess I should call ORD up one day :wink1:
thanks,
James
