I've been doing some research into various lift kits for my 2500 'burb. Suffice to say there are a lot of opinions and not a lot of facts that I can easily find. I'm hoping there are a few folks here that can provide some wisdom on lifting a 3/4 ton GMT800, staying with IFS, dealing with the autoride BS, and what (if anything) I actually need to do about the autotrack TCase.
The vehicle is a 2002 suburban 2500, 8/1, LT, AutoRide, AutoTrack, 4.10 gears
The goal is 33" or 35" M/T style tires with 3" to 6" of lift. I'm leaning about 60/40 toward less lift w/ 33's. Can't make up my mind. It must maintain reasonably good highway manners as the wilderness areas I frequent include stretches of 80mph highway to get to. I also plan to tow a popup camper which weighs nothing compared to the tow rating of a 3/4 ton vehicle. No rock crawling. Just snow, mud, and deep rutted out designated trails. I'm not interested in lifting it just to make it taller. I want it to ride better and perform better, knowing that big tires and a lift will degrade the high-speed and towing performance to an extent.
SAS is beyond my skill / comfort level and is basically a $10k job to complete, so it's out of the question unless someone can convince me it's just that damned much better at what I want to do.
I've been looking at the RCD (Race Car Dynamics - the kit ORD sells) and BDS lift kits but i'm open to other suggestions.
- AutoRide: I see many kits mention that they are not compatible with Autoride. I assume the fix is to delete Autoride which i've seen some videos of and it seems pretty easy. Can anyone confirm if that's the only reason and that mechanically everything will fit all the same?
- Autotrack: I've read some folks saying you have to replace the front drive shaft with any lift over some arguable number of inches. What's the deal with that? Should I plan on adding a front drive shaft into my budget for this project?
- CV shafts: Some people have said they break too easily, some lift kits have lowered differentials to correct the angles, some people use longer shafts from later model years. What's the deal? If I lower the diff does it get rid of the problem? Are the shafts just weak, or are people over-stressing them through bad geometry?
- Exhaust: How do I know if I will need to modify something there? RCD says "some models" and BDS says only gas models need it.
- Gears: I've seen people argue either way. I'm tempted to think that with the 8.1 motor I won't have issues running 35's on 4.10 gears. Anyone have experience on that combo?
